Budget (including currency): 650~ American Eagles
Country: USA
Games, programs or workloads that it will be used for: apex legends, graphic design (Adobe CC) and minimal 3D modeling
I have a 1660 super GPU before we begin, I did some research and threw together a quick pc part picker. Would someone be able to help me out, could I downgrade/ need to upgrade anything??
Currently Micro center has the i7-9700k on sale that's why I put in my own price.
Kind Regards,
Jake, from StateFarm
https://linustechtips.com/topic/1284834-planning-for-first-build/
3 minutes ago, Dr Seuss said:
Do you really need a liquid cpu cooler? That seems a little overkill for a budget build, especially with a 1660 super. And is there a reason you're going with mini itx?
No real reason for the water cooler, if there's a cheaper/better fan that would be awesome as clearly, i am a noob. As for the Mini itx, i was hoping to have a white mini case, just for easy storage tbh. that way i could sit it on the desk.
I would go with a micro atx case and mobo, as they are probably the cheapest route out of the three sizes. As far as a cpu cooler, Cooler Master Hyper 212 Evo is my base recommendation, by far not the best cpu cooler, but in my experience the best for budgeting. Just don't go overclocking your cpu and expect it to keep up without checking
The problem with mini itx cases is that they are so small they can heat up really easily if it doesn't have good air flow. If you can get the fans in and can afford the itx, go for it, but the atx or micro atx are a lot easier to keep cool as there is more space for airflow
Edited by Dr Seuss
forgot something
Finally clicked thanks!
Edited by IIStateFarmII
Dumbass over here
If you are going to grab a z390 you need to capitalize on one of things currently locked down on lower chipsets. The ram speed at least grab a 3200 mhz kit.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
