I need to know are there any HTPC cases that can take a mATX board and my 254mm graphics card.
Im tempted to buy a cheap case and chop it up just for the motherboard tray; with PCIe riser card to lay the GPU flat and some wood/vinyl work to make it look reasonable - at least in this set up I can take it to lan parties.
https://linustechtips.com/topic/1284798-htpc-case-required/
I mean, tons. Just go to PCPartPicker and filter for that length. But I feel like you have more requirements you're not telling us...
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327483
https://www.thermaltakeusa.com/core-g3.html
I use that for my htpc case. It's plenty long enough for almost any graphics card. 320mm+ according to the specs. But be warned it needs an sfx power supply and it's cpu cooler hight restrictions are a little strict
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327487
1 minute ago, Mling said:
prob need a small form factor PSU that can power a 5700XT, depending on the case.
No, I mean what do you want this case to do other than fit a GPU of that length? cause, like, any mid-tower can do that. but, if that's all you wanted, you wouldn't be here. so please, give us what your requirements are. is there a size constraint? aesthetics/colour? drive compatibility? cooler compatibility??
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327489
i want it as small as possible. hopefully it will sit behind my TV.
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327492
That's a huge distinction! You should lead with stuff like that! A sandwich-style case like the Dan A4, Ghost S1, Formd T1, etc. are probably the smallest cases with long GPU support.
If you wanna spend less money, find a similar case on aliexpress/taobao, or go a little bigger and get an NR200P or maybe go for a taller case like a Dr Zaber sentry, silverstone RVZ-0x (1,2,3), node 202, etc.
Edit: of course, since you didn't give me other requirements, these don't support tons of drives, huge CPU coolers, etc. because you didn't ask for those things. hopefully you don't need them
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327494
Just now, Arrogath said:
and you want to use an mATX board, best of luck. Most of the good small case options only support mini-itx
oh yeah oops i just went ITX cause i saw as small as possible.
uh, tiny mATX is harder, maybe the chimera cases??
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327503
yea well I have 2600 and a 3200G that I can use but I can't find any compatable itx boards in stock.
that is what I am looking for but on amazon the shipping cost to NZ is $100.
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327515
Well I can't talk about stock in another country, but I can say basically any b350,x370,b450,x470,or x570 board will work. some b550s might not, but a lot probably will too (but I'd double check those). so make sure to check those before giving up. those are low-power parts, you don't need a high end board to run those chips.
sry i don't have more mATX experience, my mATX builds haven't been tiny (arc mini r2, core v21, nr400, i used a corsair 280x but for an itx board, my router is matx but just runs naked on a storage bin...). some cases focused more at NAS use (silverstone makes a bunch) are short, but not necessarily "small", could give them a look. they'd probably fit into a media console, but not behind a tv
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327527
i literally just found a itx motherboard for the 2600
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327569
1 minute ago, ComputerBuilder said:
they come to over $200 NZD after shipping. I can get a brand new one locally for that price.
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327598
7 minutes ago, ComputerBuilder said:
tell me before dammit
i did but nm there is something else. If I go with a $200 ITX then I also need a new $200 small form facter PSU. Which brings me back to I might have to mod a case to make it slim enough to fit behind the tv.
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327615
why does fucking nz always have the worst prices on hardware
https://linustechtips.com/topic/1284798-htpc-case-required/#findComment-14327742
