How to remove xlr cable?
Go to solution Solved by Derkoli,
3 minutes ago, Duckster said:
https://www.sweetwater.com/store/detail/XLR20--pro-co-exm-20-excellines-microphone-cable-20-foot
this is my cable. The male side is the one I'm worried about.
You just need to give it a good yank. The male connectors for microphone inputs typically aren't locking.
Do you mean unplug the cable? You press on the tab and pull.. unless i'm missing something there.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
I don't think there's a tab there... https://www.sweetwater.com/store/detail/M2--motu-m2-2x2-usb-c-audio-interface
thanks for the reply!
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
2 minutes ago, Duckster said:
are you sure? I saw a latch and I'm scared I'll break it.
I can't see any tab from the pics of both the cable and interface. All of my interfaces don't lock iirc. Gently pull the cable until it comes out, it will be a bit tight if the cable is new.
Thank you everyone who responded. It worked!
