Hi, I recently got my RTX 3070 and so far the performance has been less than anticipated, with fps on COD cold war being at around 90-110fps on any graphical settings (minus ray tracing, the frames drop to around 70-80) all on 1080p
and the same on cyberpunk ( I have changed the config files to use more RAM and VRAM) and I have a constant 40-50 fps regardless of the settings, even if I enable ray tracing. I have uninstalled and reinstalled drivers, installed a fresh version of windows. Any solutions or suggestion to change about my rig ?
specs
CPU-Ryzen 5 2600 (oc to 4ghz 1.425v)
Mobo-msi x470 gaming plus
CPU Cooler-NZXT kraken x52 (240mm)
RAM-Corsair vengeance 2x8gb 3000mhz
PSU EVGA 600w 80+
GPU-EVGA RTX 3070 XC3 ultra
https://linustechtips.com/topic/1283636-rtx-3070-low-performance/
1. Cyberpunk runs terrible on anything but medium/high mixed settings at 1080p with that hardware (COD is a very low resource game in comparison, and has far less run-to-run variance)
2. Changing the config files doesn't actually work (See for reference: Cyberpunk Ryzen CPU Updates: Cyberpunk 2077 1.05 Benchmarks vs. Hex Edit Mod - YouTube)
3. Ray Tracing is still not possible while maintaining high frames at this time, even on current-gen RTX hardware
4. Your CPU is 2 generations old, and bottlenecking the 3070 (See 12:00 in this video for reference: Cyberpunk 2077 CPU Benchmarks: AMD vs. Intel Bottlenecks, Stutters, & Best CPUs - YouTube)
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
I'm gonna have to disagree with you, out f nowhere, today when i booted up i am now getting 130-150fps in cod and a constant 60 in cyberpunk
It is well within your rights to disagree. However nothing's going to change until you realize it's the truth, sorry.
60fps is not good (especially with a 3070). First-person shooters are meant to run at high refresh. Role-playing games are more meant for ~85fps with better scenery. If you're getting less than ~85fps in Cyberpunk, then I'm sorry, but it's either something with your settings, or your build is all wrong.
**I speak from experience, not opinion.
[Main Desktop]
[Stream Encoder]
[Garage]
