Adding more fans
Go to solution Solved by Electronics Wizardy,
You can use a fan splitter to connect multiple fans to one port.
But also why so many fans, there is basically no benfit going above 3 fans in most cases.
2 minutes ago, ReXoN said:
I have asus tuf gaming h470 mb with cpu fan and 3 fans already installed , I would like to add 2 more fans but I dont have any 4 pin fans left in the mb. what can I do?
You can get PWM Splitters or get these some neat Artic P14 PST https://www.arctic.de/en/P14-PWM-PST/ACFAN00125A so you can daisy-chain them
(I recently swapped ALL my fans to these and they're actually really good, MY GPU and HDD are the noisiest parts of my PC now)
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/1283205-adding-more-fans/#findComment-14316629
I thought about the fan splitter but there is non in my country so Im looking for another way... but thnx for the help if 3 fans is ok then I keep it that way.
https://linustechtips.com/topic/1283205-adding-more-fans/#findComment-14316705
