Leaking capacitor?
Go to solution Solved by rhyseyness,
They're aluminium caps which have a lifetime- Usually they last about 10 years before needing to be replaced.
If you're not electronics-y, I'd recommend you buy a new PSU rather than replacing them.
Are these capacitors leaking or is it just glue?
For context, the pc works fine, sometimes it makes a rattling sound which I thought was a fan hitting a cable. I opened the psu to verify and found no clearence issues, but I found this.
The psu is just a generic "500w", made by Hantol, 10+ years old.
As you can see I'm not knowledgeable at all at this stuff so any input is appreciated.
https://linustechtips.com/topic/1283116-leaking-capacitor/
Should never open a PSU, high electrocution risk. Especially with those capacitors, they hold a few hundred volts at a time and can take days to drain fully. I wouldn't touch anything in there if I were you, even if they were leaking.
Main PC [ CPU AMD Ryzen 9 7900X3D with H150i ELITE CAPPELIX  GPU Nvidia 3090 FE  MBD ASUS ROG STRIX X670E-A  RAM Corsair Dominator Platinum 64GB@5600MHz  PSU HX1000i  Case Lian Li PC-O11 Dynamic  Monitor LG UltraGear 1440p 32" Nano IPS@180Hz  Keyboard Keychron Q6 with Kailh Box Switch Jade  Mouse Logitech G Pro Superlight  Microphone Shure SM7B with Cloudlifter & GoXLR ]
Server [ CPU AMD Ryzen 5 5600G  GPU Intel ARC A380  RAM Corsair VEGEANCE LPX 64GB  Storage 16TB EXOS ]
Phone [ Google Pixel 8 Pro, 256GB, Snow ]
https://linustechtips.com/topic/1283116-leaking-capacitor/#findComment-14316144
Get a new power supply...that thing is outdated and reached its life expectancy, with only the risk of failure climbing.
And please don't open a power supply up unless you have extensive knowledge with electricity. Its not worth your time or money to repair it.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1283116-leaking-capacitor/#findComment-14316145
I don't plan on changing them or anything like that, I know there's a high risk involved, I was only planning on moving any cables that could be in the fan's path. Thank you for your concern.
https://linustechtips.com/topic/1283116-leaking-capacitor/#findComment-14316148
https://linustechtips.com/topic/1283116-leaking-capacitor/#findComment-14316150
Tbh if the power supply doesn't work I'll just save the components, it's pretty much useless for anything other than very low end gaming. Thank you.
https://linustechtips.com/topic/1283116-leaking-capacitor/#findComment-14316157
Thank you.
https://linustechtips.com/topic/1283116-leaking-capacitor/#findComment-14316165
