Hey I got a new PC and would like a new wireless card. My budget would be 80 USD.
Thanks for the help
CPU, 8350 @ 4.3 ghz | CPU COOLER, Hyper 212 EVO | ,MOBO, Gigabyte UD3 AM3+ 990FX | RAM, 8 gb  G.Skill ripjaw 1866mhz | GPUASUS 7970 | CASE, Corsair 230T black and red STORAGE, WD caviar blue 1 TB 7200 rpm | PSU, XFX 750 watt 80+ gold | Keyboard, K70 mx blue (black/red) | Mouse Razer naga hex, | Monitors, Asus VG248QE 24in 1080p, Dell 24in monitor 1080p |
https://linustechtips.com/topic/128311-wireless-card/
What interface are you using?
https://linustechtips.com/topic/128311-wireless-card/#findComment-1706454
I would be using PCI
https://linustechtips.com/topic/128311-wireless-card/#findComment-1706579
Also I could us a wired connection, but my ethernet port on my mobo does not work correctly, it shuts on and off. Is there an option for a ethernet port for a PCI expansion card?
https://linustechtips.com/topic/128311-wireless-card/#findComment-1706587
Yes, that's an option. However, I'd suggest checking if you have properly installed your drivers first.
https://linustechtips.com/topic/128311-wireless-card/#findComment-1706697
Where would I get my drivers? from the CD that came with the mobo?
https://linustechtips.com/topic/128311-wireless-card/#findComment-1709269
Go to your motherboard's website and download them from there.
https://linustechtips.com/topic/128311-wireless-card/#findComment-1709373
