HELP BSOD SYSTEM THREAD EXCEPTION NOT HANDLED
@WaggishOhio383 any idea if new windows will automatically detect windows key? Its an oem version
Chasis: Lian Li O11 Dynamic Evo || PSU: Seasonic PX 650 || Mobo: MSI Z690 Pro A || CPU: Intel i5 12600K || CPU Cooler: Lian Li Galahad AIO 240 || RAM: G.Skill Ripjaws V 32GB @3200 || GPU: AORUS 4070 ti Elite || Boot Drive: Samsung 850 EVO 250GB || Secondary Drive: Crucial MX300 525GB || HDD: WD Caviar Blue 1TB || Intake Fans: 3x Lian Li UniFan SL120 || Exhaust Fans: 2x Lian Li UniFan SL120 || Mouse: Logitech G Pro Wireless || Keyboard: Das Keyboard 4Q with Cherry MX Browns || Monitor: Acer Predator IPS 165Hz GSync
I honestly don't know. Don't have much experience with how Windows 10 product keys work on custom builds.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
Its ok i think it will. Another question, and really thanks for your help this far. I decided to give the 850 another chance. If the drive was indeed broken, how can windows be installed on it?
It's not that the drive just doesn't work. It just might be failing, which is causing the constant crashes when you try to load an OS off of it.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
So now if i restart maybe i will run into a bsod again?
