HELP BSOD SYSTEM THREAD EXCEPTION NOT HANDLED
As the title suggests I can't log into Windows whatsoever. I instantly get this bsod. I also cant log in with safe mode. Instant bsod again. Any help? Though i feel this is helpless.
Chasis: Lian Li O11 Dynamic Evo || PSU: Seasonic PX 650 || Mobo: MSI Z690 Pro A || CPU: Intel i5 12600K || CPU Cooler: Lian Li Galahad AIO 240 || RAM: G.Skill Ripjaws V 32GB @3200 || GPU: AORUS 4070 ti Elite || Boot Drive: Samsung 850 EVO 250GB || Secondary Drive: Crucial MX300 525GB || HDD: WD Caviar Blue 1TB || Intake Fans: 3x Lian Li UniFan SL120 || Exhaust Fans: 2x Lian Li UniFan SL120 || Mouse: Logitech G Pro Wireless || Keyboard: Das Keyboard 4Q with Cherry MX Browns || Monitor: Acer Predator IPS 165Hz GSync
If it's also happening in safe mode, this is probably a hardware issue. First thing I'd do is clear CMOS as @Tan3l6 suggested, and then reapply XMP on your RAM. If that doesn't work, try testing your RAM sticks by booting with only one stick inserted (testing each stick individually to see if one of them is faulty).
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
Everyone online says its a driver issue. Should i proceed with clearing cmos? @Tan3l6 @WaggishOhio383
If it's a driver issue then it shouldn't crash when booting into safe mode. Clearing CMOS is a good place to start.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
@WaggishOhio383
i removed the battery, short circuitrd the pins, now pc got power, restarted, and now it has power but nothing happens..
Did you unplug the PC before you took out the battery? And when you say you short circuited the pins, do you mean the CMOS clear jumper? You should only do one of those two things, not both. And if you take out the battery you should hold down the power button on your PC to drain excess power from the system while it's out. It's also generally best to leave the battery out and the PC unplugged for 30 minutes or so.
Hopefully you didn't try to take the battery out while your PC was plugged in with the power supply on. You could have fried your motherboard.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
No no the pc was unplugged of course. Fans are turning,
gpu leds are on, just nothing happens on screen. No windows logo, no motherboard logo, no bios, nothing
Try leaving the battery out for 30 minutes, see if that fixes the issue.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
Ok its on, im into uefi. What now? I reset time and use F5 settings? Do i turn on xmp? I5 6500
I would try XMP. If that doesn't work then the next step would be to test with only one stick of RAM inserted.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
Yup straight into blue screen again. I have windows media tool on a usb flash drive. Should i reset or format maybe?
Or test ram first?
It restarted after the BSOD on a black screen again. Thats so f*** annoying
Just now, Tan3l6 said:
Yeah RAM test is a good idea.
Memtest86+ i'd recommend.
I cant get into windows remember?
I'd be more inclined to say you may be dealing with a faulty hard drive / SSD. I don't think it's an issue with your Windows installation. But try booting with a single stick of RAM first, testing each stick individually to see if one is faulty
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
Ah right, if no other machine available then yeah... can't make a USB stick.
But i already have a usb with windows media tool on it right next to me. Should i reset? Or format?
Just now, WaggishOhio383 said:
I'd be more inclined to say you may be dealing with a faulty hard drive / SSD. I don't think it's an issue with your Windows installation. Try booting with a single stick of RAM, testing each stick individually to see if one is faulty
Hmm yesterday i had a different BSOD that pointed to a failing ssd. Its weird its 4 years old 850 evo, with wich i was very careful.
I'd go with what @WaggishOhio383 recommends - test one stick of ram at a time.
If you'd have another SSD/HDD you could try swapping that next.
Pax vobiscum
@WaggishOhio383 @Tan3l6
every single ram stick got me straight into blue screen.
so:
clear cmos didnt work
ram is probably not faulty
what should i do? Format and install windows on the same ssd? Or format the second ssd too, and install windows there?
I would completely remove the current boot drive from your PC, format the second SSD, and install windows on that
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
Shouldnt i give it a chance in case its a gpu driver? Actually the thing is i have this driver for days so it cant be it. I think the 850 evo is long gone. Just 4 years lifespan. Thats a lot less than i expected from this drive tbh
