9900k Overclock Help
22 minutes ago, Dankcube said:.
if you are driving through a crowd, it's one of the most intensive things you can do in the game, my cpu usgae will spike to 90-100% while gpu will also be 100%, MOST of the time it's a gpu bottleneck at 4k/98fps, i can't play with rtx on, settled with medium dlss performance, overclocking the cpu doesn't do much below 80fps, wouldn't recommend it either with a h100i. Also wouldn't recommend upgrading from a 2080 ti to a 3080, the 9900k won't take full advantage of it but i wouldn't call it a bad duo either. Personally waiting for the 3080ti for the 9900k (it's a inefficient).
1% lows at 81.5fps, a 5.1 oc with 4.9 ring brings it up to about 88, it does help the dips but whether it's worth it is up to you.
TLDR: most of the cpu bottlenecking happens above 80-100fps, and there are areas where no cpus stay above 120fps, don't worry about it. It's mostly a gpu bottleneck.
