Hello. I'm new to PC gaming so not overly knowledgeable.
A a month ago I moved to PC from console. I mostly play Warzone, for the first weeks everything seemed to be running fine, I was regularly getting around 120-130 FPS with a minimum drop of around 115 whilst playing on 1440p and even more on 1080p. For the past week or so my frames have been dropping all the way to 85 and average around 95-100 with the exact same settings. I've also noticed than when I switch back to 1080p my frames now stay the exact same as they are on 1440p. I've searched a lot online and altered my graphic settings to try and gain more frames but nothing seems to be working.
Any suggestions? Thanks
Also, i'm using a 2080 Super with a i9-7700K if that helps.
https://linustechtips.com/topic/1282472-help-needed-with-frame-drop-on-warzone/
  • 2 months later...
Any update?? I'm in the same situation as you.
Some reported that Firefox being opened messes with the VRAM, try closing it if it's open. I, however, only ever have warzone open and I have been experiencing huge drops. My temps are perfect and I used to get 160fps consistently.  Now I'm lucky if I get 100fps. I have a 2080 super, 32gb ram, i7 10700k, 1440p 165hz monitor. When my fps drop, sometimes I'm able to fix it for 1 or two games by restarting or rebooting, but then it goes right back down for the next game. This is so frustrating. My 2 brothers have the same exact setup as me and they get 160fps consistently. I have no idea what's going on.
So far I have tried:
1. unistall/reinstall
2. reverting to the last Nvidia game ready driver that worked
3. setting warzone as a priority in task manager
4. dropping my graphics down super low in game
5. turning off g-sync
6.going into bios and making my ram go to 3600
7. scan/repair WARZONE
8.I'm sure there's something else I've done but can't think of.
If anyone knows of a solution, let me know. It's crazy my $3k computer setup is doing this. smh
