PC wont work
Go to solution Solved by GOTSpectrum,
4 minutes ago, DoctorNick said:
Remember to power off PSU. Remove battery for longer if it dosen't work
I somehow always forget to say this. I guess I just wrongfully presume everyone has at least basic knowledge.
3 minutes ago, WestTexan said:
I have a B450 MSI Tomahawk mobo. Could you please tell me exactly what to do? Im still new to this,sorry.
Turn off the switch on the power supply at the back of the computer.
Then find the coin cell battery on the motherboard, it should be a shiny round piece of metal.
There will be a small metal clip on one side, to remove the battery you apply pressure to this tab.
Leave the battery out for at least 30 seconds, then push the battery back into place.
Turn on the switch to the power supply and try to boot the computer.
I thought my ram wasn't running at its proper speeds so I changed a bios setting from auto to 3200mhz
I then realized that it was always at 3200mhz so I changed the 1 setting I changed back to its original setting of Auto
I just exited bios by clicking on save and reboot. I waited 5 minutes and it was not rebooting so I manually shut down my pc by holding the power button down on my case
Fast forward to now and my PC switches on and my green case light is on like it always is but my keyboard and mouse are not getting power neither is my monitor it says no input
What can I do?
https://linustechtips.com/topic/1282294-pc-wont-work/
Resetting the BIOS would probably fix this, some motherboards have CMOS clear button, others have a small jumper on the board.
Alternatively you could pop out the small round button cell battery on the motherboard for 30 seconds and this will also clear the BIOS
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310157
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310174
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310178
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310192
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310197
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310201
Doing that now. Hopefully it works
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310207
F1 or F2?
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310215
1 minute ago, WestTexan said:
F1 or F2?
F2
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310220
2 minutes ago, WestTexan said:
Okay I am back at my desktoo everything working fine but will I need to change my ram xmp in the bios? Not sure if it will run at 3200mhz after I did all that.Task manager says my speed is 1067mhz and not 3200mhz
1067*2 (DDR=double data rate)
Yes go to bios and turn on XMP, press F10 + enter to save and exit
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310237
It is actually running at 2033MHz as you are seeing the true clockrate. DDR stands for double data rate meaning that there are two transfers for each clock cycle.
You can go into the bios and enable XMP, see what speed it tried to run it at without altering any other settings
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310238
I  changed A-XMP to Profile 1
And adjusted DRAM frequency changed to 3200mhz when I did this.
Do I press Save Changes and Reboot?
https://linustechtips.com/topic/1282294-pc-wont-work/#findComment-14310246
