hey! i just bought an H61 LGA 1155 motherboard and it sounds like the fans are constantly spinning at max rpm's, i have no settings to change this in the BIOS and other software like MSI afterburner doesn't seem to change anything either, any ideas on what i could do to turn down the fan speed?
i included a picture of the motherboard since i'm not great with computers and mighthave explained the model poorly.
https://linustechtips.com/topic/1282019-cpu-fan-cant-slow-down/
Has a 4 pin PWM fan header, odd BIOS is so locked down, whose the manufacturer?  Is this one of those chinesium boards?  If so I would recommend using the PSU to power the fans and put voltage regulators on them.  Or can try Speedfan but I never have success with that program.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1282019-cpu-fan-cant-slow-down/#findComment-14308333
Use a resistor cable to reduce the fan speed by capping the voltage or buy yourself a fan controller. Noctua usually ships those cables with their premium brown and the new chromax fans.
https://linustechtips.com/topic/1282019-cpu-fan-cant-slow-down/#findComment-14308335
thanks for the great advice!
https://linustechtips.com/topic/1282019-cpu-fan-cant-slow-down/#findComment-14308386
