3090 FTW3 Hybrid paired with a 2600x
5 hours ago, jones177 said:I don't consider at match a big issue. With the pricing of things now leapfrogging upgrades makes sense.
I think the issue will be putting it in your case. The 20 series used 120mm radiators so they were not that had to fit. The 30 series use a 240mm radiators.
My case already has a 360mm AIO on the top for the CPU. Putting it in front may restricted air to the parts that are not water cooled.
That is what is stopping me hitting the autonotify button on one.
Oh, I have a Thermaltake View 71...so I'm not too concerned with space. I just need to figure out how I will arrange it as I do already have another 240 radiator for the CPU in it. I can put it at the top with the other radiator since there space to hold 480 radiator in it or I can put it on the back right in between the motherboard and the front fans
