Budget (including currency): $2500 USD
Country: United States
Games, programs or workloads that it will be used for:
Games: Cyberpunk 2077, Red Dead Redemption 2, Witcher 3, Final Fantasy 15, Shadow of the Tomb Raider, Minecraft, Monster Hunter World, Assassin's Creed Valhalla.
Apps: OBS, GIMP, OpenShot, Discord, Clip Studio Paint
I already have ssds for storage. I will be using this PC for streaming, video editing, and photo editing, and drawing.
I will not be needing any peripherals.
I'd like to run my games at 1440p at around 100 fps. I'd like to move up to 4k a little later when there are more options for monitors and I'd like to have at least 60 fps for 4k.
I am not set on the GPU. I will be buying whatever I can get my hands on between the 3080 and 6800 xt. I would prefer to go Nvideo for the nvenc encoder though.
I would like recommendations on which partner cards are the best for GPUS though since I'll be trying to buy whatever I can get my hands on at the local store.
I would also like some advice on memory. I'd like to go 32gb and wanted to know whether I should do 4 sticks or 2 sticks. If someone could explain to me what single rank and dual rank are and why one is preferred or the other that'd be great as well.
Edit: I've neglected to put a power supply because I am unsure what to get. If possible I'd like several recommendations that fit the budget and need since I will be trying to get them at my local store if possible. I will buy online however if the options are better, which they most likely are.
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($549.99)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.95 @ Amazon)
Motherboard: Gigabyte X570 AORUS MASTER ATX AM4 Motherboard  ($359.99 @ Newegg)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($169.99 @ Newegg)
Video Card: Asus GeForce RTX 3080 10 GB TUF GAMING OC Video Card  ($699.99)
Case: Cooler Master MasterCase H500P Mesh ATX Mid Tower Case  ($164.99 @ Amazon)
Total: $2034.90
Generated by PCPartPicker 2020-12-14 22:15 EST-0500
https://linustechtips.com/topic/1281323-help-on-new-build/
Total: $2034.90
spending $360 on a mobo seems like a waste and a $170 case also isn't a good investment when it is not even a case for custom watercooling
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303428
Do you have any recommendations for a better mobo? I'm just going off the tier list on the forum so any insight would be helpful.
I'm open to case suggestions as well. I'd prefer white though. I was also looking at this but I've read the cooler master one had better air flow.
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303445
i'm working on an improved parts list and will get back soon
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303451
all the evga and strix cards are best in terms of clock speeds and cooling but tuf cards have caught up and nowadays most aib cards are in $730-$850 price point and msrp aib cards for the 3080 are non existent and you can choose between the tuf costing ~$760 with lower clocks, ~$810 for the ftw3 with good clocks and ~$850 for the strix with the best of everything
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303487
PCPartPicker Part List: https://pcpartpicker.com/list/N4pM4d
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler  ($99.95)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  ($199.99 @ Newegg)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3600 CL16 Memory  ($229.99 @ Newegg)
Video Card: Asus GeForce RTX 3080 10 GB STRIX GAMING OC Video Card  ($850.00)
Case: NZXT H510i ATX Mid Tower Case  ($99.99 @ B&H)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($134.99 @ Corsair)
Total: $2164.90
Generated by PCPartPicker 2020-12-14 23:03 EST-0500
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303497
Total: $2164.90
Thanks for the recommendation. So I should go with 4 sticks for ram? Also is the case okay? I thought the NZXT ones had bad air flow. I won't be water cooling ever or using aios btw.
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303554
the nzxt's are just ok and for $100 it's good value, they might not be the best but they do the trick and ryzen isn't power hungry and doesn't run very hot.
4 sticks of ram gives about 10% performance improvement according to a recent gn video and the nhd-15 chromax black manages to perform well while not look ugly in true noctua style
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303570
I'm okay with spending more if it's better quality. Also I couldn't care less what color the cooler was or how the inside looks.
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303592
https://linustechtips.com/topic/1281323-help-on-new-build/#findComment-14303610
