Anyone know when the 3060ti will restock? Im about to buy the 5700xt but not sure if I should wait for 3060ti to restock. There is a limited amount of 3060ti's at my nearest microcenter but its $470. Soooo cop 3060ti for $470 or get the 5700xt for $440, orrr just wait fro 3060ti but just lower price ($440)
https://linustechtips.com/topic/1281173-need-help-choosing-gpu/
yes I would also reccomend the 3060 ti. At this day and age, that is a killer deal!
https://linustechtips.com/topic/1281173-need-help-choosing-gpu/#findComment-14302214
4 hours ago, Pxrdeep said:
sooo 3060ti just got out of stock... 5700xt it is then?
The 5700XT is a good card but you would be better off waiting for a restock of the 3060 Ti. Most benchmarks show it almost equal to a 2080Ti. The 3060 Ti will give you better frames for longer than a 5700XT which means it will last you longer.
CPU i7 14700K | CPU Cooler Noctua NH-U12A | Motherboard MSI Pro Z690-A | GPU Zotac Airo RTX 4080 | RAM 32 GB GSkill Ripjaws V 4400
Mhz |
 Monitor Alienware AW2721D / Gigabyte M28U | PSU ASUS ROG Strix 850G
https://linustechtips.com/topic/1281173-need-help-choosing-gpu/#findComment-14303059
