Are all power cables the same?
The CPU (EPS) connector has 4 pairs of wires : ( +12v and ground wire ) x 4
Let's say your CPU consumes 200 watts... that's 200 watts / 12v = 16.6 A of current.
These 200 watts will be sent through those 4 pairs of wires so the current is evenly spread across all pairs, so each pair of wires will carry around 16.6 A / 4 = 4.1A of current.
The connector standard used ( Molex Mini-Fit Jr) defines the maximum current through each pin to 9A of current, but the people that defined the ATX / EPS standard restricted the connectors to 7A per pin for extra safety. There's a variation of the connectors which are rated for up to 13A of current per pin.
So even if your CPU uses 200 watts (which is a lot), Ryzen 16 core gets close to this when overclocked, it's still just barely at HALF the rating of the connectors.
The wire themselves (AWG 18 or AWG16) are rated for at least around 10-13A so those are also safe.
Most likely the pin inside the plug was a bit loose, or there was something causing some resistance between the connector on motherboard and that pin, causing it to spark or overheat.
edit:
People above keep talking about mains power cables but you say cpu cable.
As for mains power cables... they're rarely a problem, but some are looser than others at the connector end, so if the connection isn't tight, there can be problems.
Unless your computer consumes more than 600-800 watts, any power cable should work fine.
Even cheap mains power cables should be rated for at least 10A , which at 110v AC is good for a computer consuming up to 500-800 watts , with some room to spare ... 800w/110v = 7A + 3A reserves for fluctuations and bursts.
