Mining rx 570 fix
3 hours ago, mariushm said:It's time to actually read the code on the memory chips and see if you have Samsung memory chips.
It's possible the guy took bios from another card with Samsung chips and by luck it worked, who knows.
If your card actually has Samsung memory chips then if you can't find an original bios with Samsung memory settings, I'd suggest searching for a bios from another manufacturer with the same or very close to same power and temperature limits and have your memory chips supported.
Turns out, i couldn't flash the original bios from the links you provided, because device id was not the same and i got an error message about missmatched id. So, i found another bios for the asus expedition on tpu(that one was not verified), i saw on the box that i have the non oc version of the expedition, and it had the hynix memory modules, despite it saying it was samsung, so i went with my gut, flashed the bios and it worked. Now the driver installs without a problem, and also gpu-z shows correct id and hynix as the memory manufacturer.
Thank you for your help, really appreciate it!
