Need help
Go to solution Solved by gamer3069,
Thanks for the help everybody, I used some soapy water and isopropal alcohol to clean the board and IT WORKS, I am currently using it as I am typing this and it is purring really nice.
once again, thanks for the help.
15 minutes ago, gamer3069 said:
Hi im having some trouble, I got a GeForce GTS 450 GDDR5 1gb card from the recycling center and one of the DVI ports looks like it has some corrosion and dosent work. What should I do to fix It?
Throw it away.
You'll spend more in time and parts than it's worth.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1279500-need-help/#findComment-14289911
Since its corrosion I am not sure it would work, but if you had an oven you dont care about, and cook edible food in afterwords - google "reball gpu in oven"
It can possibly reflow the solder, but with corrosion...I doubt it...and may brick the card completely.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1279500-need-help/#findComment-14289988
37 minutes ago, gamer3069 said:
Just asking could I put some baking soda dater on it first and let the corrosion go away or is that a bad Idea?
also The dual dvi card Im using right now it I think a 210 so this might be a little better for the computer
It wont cause the traces to reattach, the corrosion caused the wires to no longer communicate.  The only reason I suggest googling "reballing" is because there are times when you heat the solder enough in an oven that it "reflows" the traces and they reconnect.
However as long as baking soda isnt conductive it shouldnt be an issue to try if you feel like it
https://linustechtips.com/topic/1279500-need-help/#findComment-14290092
