First Build
Go to solution Solved by Helpful Tech Witch,
oh, if its a b450, then yiu just need to send amd the cpu, then they would send one to update with.
https://www.amd.com/en/support/kb/faq/pa-100 go to bottom of page
Looking for a good motherboard to fit my build
Budget:  $150 USD
Prefer: Micro ATX, 4 slots of ram, and dual monitor capability
Any recommendations?
https://linustechtips.com/topic/1279135-first-build/
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1279135-first-build/#findComment-14287252
17 minutes ago, HelpfulTechWizard said:
Does the Steel Legend have the right BIOS? I already have all of the parts in my list. I currently have The ASROCK B450M Pro4 and nothing works. My computer doesn't come on or do anything(no lights fans nothing, not even for a second). After some troubleshooting I found Its the BIOS. I've never messed with the BIOS so I figured id just get a new Motherboard.
After this I'm kind of skeptical about ASROCK... Will the Steel Legend have the same problem...?
https://linustechtips.com/topic/1279135-first-build/#findComment-14287307
Bios database
prior build:
https://linustechtips.com/topic/1279135-first-build/#findComment-14287312
