2 minutes ago, Jack Sproston said:
Yes, the SSD is compatible with the motherboard.
You'll want to use the top M.2 slot for full performance, but keep in mind ASATA3 0 & 1 will be disabled, so make sure you move any SATA devices you may have connected to those, to the other 4 SATA ports:
8 minutes ago, Jack Sproston said:
Yes as this board supports M.2 PCIe (NVMe).
4 minutes ago, The_Vaccine said:
yes. you can use any ssd in any motherboard. 99.99% of the time there will be no compatibility problems.
Ehh not quite. Some boards (especially common on prebuilt and notebook ones) only support SATA M.2 annoyingly. And that is information that is often obscured so you have people purchasing fancy NVMe drives to upgrade their laptops... only to find out it won't work since the board doesn't support PCIe on those M.2 slots.
Case in point, my ASUS VivoBook is limited to M.2 SATA.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
on a modern desktop motherboard that is not an issue. b450 pretty much always has nvme slots.
I also already looked at the motherboard name and it supports nvme.
