B550 Aorus Pro won't let me enable XMP and/or OC the memory differently.
21 minutes ago, TwisteddJoker said:Is this ,,good enough" for 3200MHz?
I can make it go to this exact setting by using "EasyTune" from Gigabyte. These are older screenshots, from few days back (with BIOS ver. F4). Are the timings etc. acceptable?
How much performance am I losing with memory set up to that "speed" compared to 3600MHz CL16?
Mind you I'm not playing the newest titles etc.
Or should I just go to BIOS and put "multiply by 32x" and add some voltage to the DRAM and SOC? Is it possible? Or do I have to mess up with timings manually as well?
Are those 'Auto' timings?
Wow...those timings are REALLY dialed back.
CL24 is really, really high latency.
If you leave XMP disabled, and just ONLY adjust the System Memory Multiplier, the motherboard has to guess and try it's own timings.
I many situations, it will end up using REALLY loose timings.
Are you not able to just enable XMP / A-XMP, and then manually set the DRAM frequency to DDR4-3200?
- Extreme Memory Profile (X.M.P.) -- Profile 1
- System Memory Multiple -- 32.00
Enabling the XMP should set the DRAM voltage for you, but you can always manually set it 1.35V just in case.
Some boards will automatically set the SOC Voltage to 1.10V (apparently), while other board's won't.
