Budget (including currency): unlimited as long as I get what I want I can get more money
Country: Canada
Games, programs or workloads that it will be used for: all types of games including ones that need good specs
Other details: hiiii I’m quite new to building pcs and I am just wondering what I need for my pc to run it properly without lag. I’m also hoping to be streaming as well. All I have picked out so far are the monitors (I want 2) a keyboard and a mouse, I’m pretty much clueless about everything else. What would I need to run these two monitors:
Main monitor: https://www.bestbuy.ca/en-ca/product/acer-nitro-27-fhd-240hz-1ms-gtg-ips-led-g-sync-gaming-monitor-vg272-x-black/14675564?cmp=knc-s-71700000074543332&gclid=Cj0KCQiAkuP9BRCkARIsAKGLE8WpZlynWhlFKUDqMFscu3b3rDjDsfVIiWNl2IrBW-GkwGmbL1afLCUaAtleEALw_wcB&gclsrc=aw.ds
Secondary monitor:
https://www.amazon.ca/Acer-VG271-Pbmiipx-Technology-DisplayHDR400/dp/B07MDXF81K/ref=sr_1_1?dchild=1&keywords=acer+nitro+144hz&qid=1606011576&sr=8-1
can someone let me know what I need to run these two monitors to the best of their abilities without lag? Keep in mind I’m also hoping to stream on these monitors. :) thank you!
https://linustechtips.com/topic/1278762-what-specs-do-i-need/
Country: Canada
Secondary monitor:
https://ca.pcpartpicker.com/guide/cnBD4D/excellent-amd-gamingstreaming-build
got this one quick, it should be good
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1278762-what-specs-do-i-need/#findComment-14284571
What system do you have right now? Just in case you just need minor upgrades or not.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1278762-what-specs-do-i-need/#findComment-14284572
