Palit 3090 gaming pro 73c under water block 33c idle
Solved by Jurrunio,
6 hours ago, Jaqen said:temps are still in the 70’s anywhere from 40% to 100% fan and pump speed.
So more speed but no extra cooling, sounds like the waterblock not getting as much heat as possible. Could be a mounting pressure issue if idle temps are fine, try tighten the screws. Otherwise the thermal paste application could be the root of the problem.
