Hello. I recently got problem with ethernet connection. When i boot it take 30 secondes to identify the network and after it work ok. got my 400mbs speedtest and no issu.
So far i have enter in command promt in admin
ipconfig /flushdns
ipconfig /registerdns
ipconfig /release
ipconfig /renew
netsh winsock reset
Double check if my ip ipv4 and ipv6 dns was automatic
reset the network adapteur
uninstall and reinstall network driver
Still the same problem. I have a dual boot and no problem with linux
Any idea. I"m about to format
https://linustechtips.com/topic/1278352-problem-with-ethernet-connection/
This might just be more for personal curiosity than a real solution but what happens if you try to connect to a different network? I wonder if it's having an issue with recognizing your network specifically or all/any networks.
