anne pro 2
hello, I want to buy an anne pro 2 to upgrade from my g213 prodigy. i dont have a bluetooth dongle and dont feel like getting one. is there a usb thing i can plug in to my pc for wireless conectivity? it can be used wired, but i dont want that.
https://linustechtips.com/topic/1278324-anne-pro-2/
Well there are bluetooth dongles so you can connect the keyboard wirelessly, but you specifically state you 'dont feel like getting one', so I am not sure what to recommend you here.
https://linustechtips.com/topic/1278324-anne-pro-2/#findComment-14281106
Yes, there are bluetooth dongles available for a few bucks.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1278324-anne-pro-2/#findComment-14281136
Trying to go off your specs on your profile. It's a little confusing because you have an Intel CPU with an AMD motherboard? If you have that motherboard, it has built in Bluetooth.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1278324-anne-pro-2/#findComment-14281160
you can plug the keyboard via usb
it doesn't have 2.4 ghz i think so bluetooth is the only option if you want wireless ...
are you really sure you want the anne pro 2 ... I have it and it's really not the best of the keyboard I have ... but it got cherry mx blue so that might not help it's cause ... also the lighting is not that good and uneven.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1278324-anne-pro-2/#findComment-14297135
