Recently, I just got my pc done and upon turning it on, it didn't boot into bios for the first time. So I updated the bios and it booted. Installed windows, updated and benchmarked. I was trying to ramp up my mem speeds thru DOCP, however, I just can't get a boot. So I managed to keep it at 3466Mhz with timings 18-20-20-20-40 1.35V. It did work... for 9 hours until it just hung and won't boot again. It's stuck at a post code error 7A. I have already reseated my ram and cpu just like in the forums. I also cleared my CMOS and reflash BIOS but still didn't work. Any suggestions?
Specs:
Ryzen 3700x
X470 Asus ROG Crosshair VII WiFi
16x2 Corsair CMW32GX4M2Z3600C18 Memory
https://linustechtips.com/topic/1277821-post-code-7a/
Specs:
Ryzen 3700x
People are saying a new mobo is the solution. Try resetting the bios and boot up to windows. Restart and try it again.
EDIT: Shit. Saw that you cleared your CMOS. But try again and reboot and then OC again.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277239
Just now, theqtguy said:
I've flashed bios for a couple of times already and still :((
Hmm. Have you tried running the RAM in different slots? I am not sure why it would do this other than that the motherboard is bust.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277248
1 minute ago, theqtguy said:
However, if I turn on the pc for 30mins and press the reset button, the code changes from 7A to code 55. Which means memory not installed
Yeah. Definitely a mobo issue.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277249
Could also be the RAM itself. Try with different RAM and see if the issue still occurs.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277252
Tried it with a new set of ram, corsair vengeance lpx, still same prob, 7A. ://
Do you need wifi?
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277258
Any mobo would do as long as it passes your standards haha
The Gigabyte B550 Aorus pro AX would be good. Not very expensive or cheap. Kinda in the middle. Very good boards for the price.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277267
anything above 3200 is not guaranteed to run on that CPU
try enabling DOCP but set speed to 3200
or maybe see if the RAM DOCP profile has 3200 MHz, some of them have 2 profiles
check ram stability with memtest86
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277312
He has tried switching to other speeds and tried a new RAM set. The motherboard has to be the issue here.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277322
i didnt see him run below 3200mhz, which is AMD's official spec (even then, it might not be stable but the chance is low)
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277329
Yes. Even reflashing bios. Probably did it 10+ times already T_T
then im out of ideas, could probably try a new board, but im not entirely sure that's the issue
https://linustechtips.com/topic/1277821-post-code-7a/#findComment-14277430
