RX 570 problem with 75 hz?
Solved by PlayStation 2,
47 minutes ago, fakhri2k said:I think it's HDMI 1.4 (with HDCP support). I haven't tried using display port since I don't have one and the monitor didn't include one. It says on the website that my monitor is Resolution (native) : FHD (1920 x 1080 @ 60 Hz) but the Display scan frequency (vertical) : Up to 75 Hz. Is this monitor only support to 60hz or what can it go to 75hz?
(I think) That's your problem right there: it's HDMI 1.4. In my experiences, HDMI 1.4 doesn't play well at all with higher refresh rates past 60Hz.
Just get yourself a DisplayPort cable and it should allow you to get to 75Hz as intended.
