Unplayable gaming build with high CPU temps
Solved by Fancy-Toast,
Turns out the issue wasn't the voltage and I didn't need to turn this down, I had to go into BIOS and turn off CPU boost instead! I don't know how it was turned on in the first place, but everything is playable again! The highest my CPU temperature went tonight after running multiple tests on multiple games was 65°c! I don't know how CPU boost was turned on in the first place, but I assume that prior to June it wasn't on.
