Gpu block flow direction
Solved by For Science!,
Just now, Heiks said:So it should be fine running intake from the left it would help routing alot
Yes, it passes over the die first, and then the VRM components.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
