As stated in the original post, "I plan on building a PC Desk case" emphasis on PC Desk Case. Reason for the clearance is I'd like to keep the "table width" below 5" since 5" is already pretty damned big. I really like the look of having the intake fan show under the glass.
Edit: the Glass will probably be about 3/8"~1/2" wide and the wood on the bottom will probably be around 1/2" wide
Why not use an SFX PSU?  Much smaller.
Assuming the PSU size standard doesn't change, I didn't want to be limited to SFX PSUs. There are less options in that category, both by company and by wattage, and are normally significantly more expensive.
SFX and SFX-L are the same height and width.  Only the depth changes.  So that opens you up to more options.
Also, they're not "significantly more expensive" than a PSU of equal performance.  You get what you pay for.  For example, an SF750 should be compared to an HX750.  Not a CX750.  If you're building this with cheap parts expecting to hit a low cost target, then I'm out.
