Not especially..
Whats the budget and use case?
https://linustechtips.com/topic/1273884-headset-advice/#findComment-14248024
47 minutes ago, Dwdunn07 said:
The budget is around 120 dollars and the use is for gaming and for listening to music.
"Gaming" headsets are nothing we recommend here in the audio forums. We tend to recommend good quality headphones with a seperate mic or some gaming headsets that actually sound good for being a gaming headset. Such as the HyperX cloud 2's or MH751's. Reason why? Because they are reskinned from studio headphones into gaming headsets. Unlike razer and logitech which I strongly hate for audio.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1273884-headset-advice/#findComment-14248228
28 minutes ago, Dwdunn07 said:
thanks for the advice I'll look into the hyper x headset
Yeah they're good for both gaming and music and are comfortable. And they usually get marked down for Black Friday and Cyber Monday sells
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
https://linustechtips.com/topic/1273884-headset-advice/#findComment-14248332
