Psu buzzing noise
Go to solution Solved by Digideath,
Is it a vibration noise? Can you push down on the psu while it's running and does the noise stop?
I posted on here about a similar issue. I figured out it was a vibration noise. Then suddenly it went away and is no longer an issue.
I'll check
https://linustechtips.com/topic/1273424-psu-buzzing-noise/#findComment-14244227
I think it might be it when I used my pc when the case was sideways the noise disappeared and the case is the node 202 so it is capable of doing it
https://linustechtips.com/topic/1273424-psu-buzzing-noise/#findComment-14244340
