Processor    AMD Ryzen 9 3900X 12-Core Processor               3.79 GHz
Installed RAM    32.0 GB DDR4 3600mhz Ram FCLK 1800mhz Corsair Vengeance RGB Pro
System type    64-bit operating system, x64-based processor
GPU AMD RX 5700XT MSI Variant
Monitor Acer AOPEN 27HC5R 1080p 240HZ
Mother Board TUF Gaming x570PLus WIFI
AIO Corsair H100I RGB Pro XT
Fans 3 Corsair non LED fans
PSU MAINGEAR 1000W
SSD 1 Crucial MX500 500gb
SSD 2 Samsung QVO 2TB
The issue I'm currently having is poor framerates in games like rainbow six siege! An example I'm running medium to high graphics no antialiasing except linear. My GPU locks it's self at 144 fps no higher or lower no matter the resolution or graphics level. I can't get it to go past that in any games really. I am using HDMI I have no idea whether or not that may be affecting my frame rates or not. Warthunder being another example I run it on high setting, easily can set it to max however my system chokes up and it drops all the down from 140+ to 40-50fps. I have no idea what is causing it to lock up. I get roughly 110 fps in COD MW the new one, For Honor it's the most stable at 180fps consistently. Any ideas on what's causing this I have the latest BIOS and Display drivers installed. I am just confused as in 1080p R6 should easily push past 144fps.
https://linustechtips.com/topic/1272822-rx-5700xt-sub-par-performance/
that's because it's locked at 144fps, which is probably an in game setting or due to freesync
what res are you playing War Thunder at?
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
It doesn't matter on or off even when i turn it off on my monitor siege stay's at 144fps no matter the quality or filtering on the graphics i am also only playing on 1080p for everything
rainbow six seige has an FPS lock in it, check it, make sure its off, the reason it stays at exactly 144 is there is something locking it.
AMD blackout rig
3 minutes ago, Spartacus U7 said:
is it within it's files?
no, the in-game settings.
AMD blackout rig
