depends.
Gaming?
DDR4 3600CL16 kit, tuned to 3200CL14
Workstation/productivity?
DDR4 3600CL16
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1272562-help/#findComment-14237908
2 hours ago, HelpfulTechWizard said:
depends.
Gaming?
DDR4 3600CL16
That makes... no sense, but anyway.
1 hour ago, Spooky45 said:
gaming
If you're just gaming, a 2x8GB 3200 CL16 kit should do, or 3600 CL16 if the budget allows for it.
Though, on that note, if you're just gaming I'd consider getting a 5600X instead of the 3700X.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1272562-help/#findComment-14238391
