2 minutes ago, Electronics Wizardy said:
do you have cgnat? Is your isp blocking the ports? How are you testing it externally?
I do not know I am testing it by trying to acces the page by my public ip
-> With my public ip is not working
-> With my local ip is wotking
on your locl network?
You gott test it from outsite your network, try using a phone with wifi off.
1 minute ago, LightDream said:
I do not know what is cg nat
So I asume that I did not installed any thing like this
well it would be done by your isp, so you wouldn't have to do nything.
if thats the wan ip you have cgnat, and can't do any port forwarding. Call your isp for a non  cgnated ip or use ipv6
Yea I would not call the ISP isn't there any workaround?
You can use ipv6
you can buy a vps a setup a vpn to that box.
Id just talk to your isp though, thats the easy solution here.
You can use ipv6
I already have a Dedicated server (64GB Ram, 12c/24t) but is in use for a minecraft server
And how to to with a ipv6
Is ipv6 setup correctly? Do the clients have access to ipv6?
Id really contact your isp its the best option here, next best is to rent a vps as a vpn box(will still your use server, but pass the traffic to a different box)
