Keycaps for g.skill km780 (red led)
Meczox_
So i want to switch my key cals to something else that looks like instead of plain black but i cant seem to find the proper layout keycaps for my keyboard does anyone know where i can get it
Most sets will be fine outside of your bottom row
Ali Express will have a load of cheap sets.
Amazon/Drop/KBDFans if you wanna spend more
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Do you know a set that would work for even the bottom row will the hyper x pudding work?
No they won't
Your bottom row is quite different from most keyboards. The key size isn't a standard format
Just now, Slottr said:
No they won't
So most wold work but for the bottom row it wont right?
TMK yes
It *Looks* like the rest of the shift keys, caps, etc are all pretty standard
12 minutes ago, Slottr said:
TMK yes
One more question will the meycaps for the 60% keyboard or 75% keyboard work too or not
Well you'd be missing a fair few keys, majority of the right side of your board
