Modular 4x4 ATX / EPS Cable
Go to solution Solved by SirCheese3,
i'm fairly sure it's for the straight power 11 or dark power pro 12 and plugs into an 8-pin connector on the psu. however, you can buy molex to 4-pin atx adapters for £6 on amazon.co.uk or for $4 usd on amazon.com.
Hi, I'm here in search of answers.
I'm currently using a Bequite! Pure Power 9 700W modular power supply with an ASUS ROG STRIX X570-E with a 3700X CPU. This power supply only has a single 8-pin EPS12V connector, I've seen this cable but I'm unsure of compatibility: https://www.bequiet.com/en/accessories/1448
I'm assuming that it will plug into my spare PCI-E port on the PSU (10 pin) but I can't find any literature on the matter.
(Also to avoid confusion my power supply is an older model, I realise that Bequite! states that my PSU is not modular)
Website with my PSU in a picture: https://www.novatech.co.uk/products/be-quiet-pure-power-9-700w-atx-power-supply/bequiet/bn269.html
https://linustechtips.com/topic/1270732-modular-4x4-atx-eps-cable/
18 hours ago, jonnyGURU said:
This is a terrible idea.
Any particular reason? It's no where near the jankiest thing I've ever done and surely splitting the load across more than just a single 8 pin is better?
Scratch all that, my PSU uses 18AWG wire for the molex connectors which comes up short when carrying the 13 amps needed for EPS12v. I would like to think that over current protection would kick in first but why gamble?
OCP would not kick in.  And UVP would kick in too late.
Getting a Molex to 4-pin EPS and plugging that in, instead of just going with the single 8-pin, would, if anything, be worse.
You don't need more than a single 8-pin, leave it unplugged. Don't buy some janky adapter that'll only do more harm than good.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
