Pcie Sense pin
Go to solution Solved by Guest,
The sense pin is a ground wire.
Hi all,
I want to start some experiments with TEC- modules. I bought some pci-e 6-pin extension cables to power the 2 TEC's and now I want to ask if it is safe to solder the 3 (2) 12v cables and the 2 ground cables with the sense pin together. I heard that the sense pin is just another ground connection, but I don't want to blow up my psu. It's a seasonic prime 1000W.
CPU: Ryzen 7 7800X3D,  RAM: 64 GB Gskill Trident Z DDR5 @6200 Cl32, GPU: Asus RTX 4090 Strix OC, Pump: 2 Aquacomputer D5 Next @ 60% (~160 l/h), Radiators: 2 Mo-Ra3 360 and 1 XSPC  RX360V3 with 21 fans @650 RPM.
https://linustechtips.com/topic/1270666-pcie-sense-pin/
Thanks @jonnyGURU, I wasn't sure about that. The TEC's should support my existing loop to reach slightly sub ambient temperatures and are cooled by their own loop.
https://linustechtips.com/topic/1270666-pcie-sense-pin/#findComment-14224474
