Budget (including currency): ~$1200-$1300 (somewhat flexible)
Country: United States
Games, programs or workloads that it will be used for: CoD Cold War, Minecraft, Watch Dogs: Legion, GTA 5, Valorant, etc., CAD, Engineering Simulations, Machine Learning
Hi everyone.  I am looking to build my first PC and wanted to get some opinions on my part choices before I make any purchases.
As for games I plan to play CoD Cold War, Minecraft, Watch Dogs: Legion, GTA 5, among some others.  I'd like to get 1440p mid-high settings in these games (not sure if this is realistic).
Also, I am an engineering student who frequently uses CAD/ECAD programs (Autodesk Inventor, SOLIDWORKS, DipTrace, Altium) as well as simulation software (ANSYS).  I have done and plan to do some more Machine Learning work, as well.
On the parts list below I chose an RTX 3070, but I will probably go with an RTX 3060ti once that card is launched (hopefully soon)
Here is a link to the PCPartPicker list I created:
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor $299.00
CPU Cooler Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler $26.99 @ B&H
Motherboard Asus TUF GAMING B550-PLUS (WI-FI) ATX AM4 Motherboard $129.99
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory $63.99
Storage Crucial P1 1 TB M.2-2280 NVME Solid State Drive $83.99 @ Newegg
Video Card NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card $499.00
Case Lian Li LANCOOL II-X ATX Mid Tower Case $79.99
Power Supply PowerSpec 650 W 80+ Bronze Certified Semi-modular ATX Power Supply $64.99
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $1257.94
  Mail-in rebates -$10.00
  Total $1247.94
  Generated by PCPartPicker 2020-11-16 20:34 EST-0500
NOTE: Some of the prices I put in myself either because PCPartPicker didn't have a price listed or I found the component at a lower price than it did.
I'm looking for some feedback on my parts list.  Any suggestions are appreciated.
I also may get a new monitor to go along with my PC.  I have been looking into the following and wondered if anyone had any input/opinions on these as well
https://www.newegg.com/p/1DG-0061-00401?Description=monoprice monitor&cm_re=monoprice_monitor-_-9SIA8SVC225371-_-Product&quicklink=true
https://www.newegg.com/p/N82E16824569005?Item=N82E16824569005
Thanks for your help/input in advance!
https://linustechtips.com/topic/1269996-first-pc-build-partsspecs-help/
7 minutes ago, chris_lentini1 said:
if 3200 cl14 or 3600 cl15 isnt to expensive you should go for that instead
9 minutes ago, chris_lentini1 said:
there can be much better psu's to be had for that price, check out the forum tier list
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
1 minute ago, Guiomar said:
Thanks for posting this. I'm planning to build a PC as well. Any experienced ppl. here can give newbees like me on tips to canvas the best parts for a PC build?
Here are some useful websites:
https://pcpartpicker.com/ (checks if your computer parts are compatible with eachother)
https://pc-builds.com/calculator/ (checks if your CPU and GPU don't bottleneck with eachother)
 (good for checking motherboard VRM quality)
(good for getting a good PSU)
Thanks man. I have a question: which is the best memory for an X570 Mobo? I'm looking at a Corsair. But I saw Linus and Gamer's Nexus use mostly some G.Skill TridentZ sticks on gaming builds. What do you suggest?
@Letgomyleghoe Thanks for your response!
Are there prices or links to product pages on this list?  I am having trouble understanding how the list/ranking works and in turn I'm having trouble utilizing the list.  I tried searching google for some of the PSUs on that list, and had little luck finding purchase links.
Also, I am looking to spend about $60-70 on a psu and you said there are many better ones to be had at that price point.  Could you please provide me with some recommendations? Links appreciated.
29 minutes ago, brob said:
@brob  Thanks for your response!
I am looking to spend a little less money than that on a psu.  Do you have any suggestions in the $60-$75 range?
check out corsair CX series theyre not modular, but they have a B rating and are extremely good for the price
AMD blackout rig
Keep in mind that the psu affects the entire system. It plays important roles in system stability and component longevity.
You might look at the Corsair CX650M or Cooler Master MasterWatt 650W. Both have 80+ Bronze rated efficiency and are semi modular.
@Letgomyleghoe you mentioned getting different ram:
What's the difference between cl14, cl15, and cl16 and why is one better than the others?
@brob  Thanks for the help! I'm looking at those and they look pretty good!
the lower the CL latency the better, 5th gen ryzen gets a measurable performance boost from better ram.
AMD blackout rig
CL is a measure of the column addressing latency of memory modules. For same speed memory lower CL means better performance. As memory speeds increase CL tend to increase. Higher speed, higher CL may outperform lower speed and CL memory, but the calculation while trivial is beyond a simple explanation.
