Can someone recommend a sleeved cable kit for a Corsair AX1200?
NoCarrier
I have a corsair ax1200 (not ax1200i).. I'm confused as not all corsair power supplies use the same type of cables.  Just looking for something with a halfway decent color selection.
Thanks in advance
I'm not an expert! In fact I'm usually just 1 google search ahead of you.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
i would recommend going to cable mods website and just selecting what you need
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Thanks in advance
The only place you're going to find custom cables for AX1200 is through CableMod's custom cable configurator:  https://store.cablemod.com/configurator/
Unfortunately, other than the 24-pin, AX1200 has a unique pin out.
Interesting, I didn't notice that until I looked at the chart again.
Saw all the blank spaces by the AX 1200... 😲
Didn't notice the 1st time because they were all blank...
corsair sells cable kits in black, red, white, and blue for $40 each, but their out rn. you can also select the ax1200 as an option in the cablemod configurator and choose each individual cable you want.
certified moron
They're not "out". The PSU is very old.  Cables for it are going to be EOL.
Just get sleeved extensions.  Sure it adds more cable to manage, but it should work fine.
I refuse to read threads whose author does not know how to remove the caps lock!
— Grumpy old man
3 hours ago, miagisan said:
Just get sleeved extensions.  Sure it adds more cable to manage....
And an extra point of failure....
And added resistance.....
ouch. for what i want on cablemods, im looking at spending $200+ usd. thats about what a new PSU costs. ugh
