Budget (including currency): £600
Country: UK
Games, programs or workloads that it will be used for: TF2, genshin impact, persona 4 golden, minecraft, csgo, valorant, overwatch/2(when it comes out)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am on 60hz and 1080P I want a balanced build, so no bottlenecking or overheating, This is my first build, Thanks
https://linustechtips.com/topic/1268624-first-build/
Country: UK
Do you already have the monitor? And a keyboard and mouse?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1268624-first-build/#findComment-14207643
https://linustechtips.com/topic/1268624-first-build/#findComment-14207668
https://linustechtips.com/topic/1268624-first-build/#findComment-14207674
https://linustechtips.com/topic/1268624-first-build/#findComment-14207707
