If you shut your system down, and it regularly performs a clear CMOS, it's time to replace it.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1268574-cmos-battery/#findComment-14207292
2 minutes ago, FireBoardThoseMuthaJammers said:
What are the signs that a desktop MOBO CMOS battery needs to be replaced?
That the BIOS complains about your settings having been reset to defaults every time you turn a PC on. Considering that these batteries have been designed to last 10+ years, it's very much unlikely your battery is a goner.
https://linustechtips.com/topic/1268574-cmos-battery/#findComment-14207296
