Please Help me
Go to solution Solved by Letgomyleghoe,
what mobo exactly? and can you get a 5600 in your area?
Budget (including currency): around 1000usd
Country: India
Games, programs or workloads that it will be used for: It's only going to be used for programming and office work
Other details (Please suggest some good budget wireless mouse and wireless keyboard)
I plan to either get the new Mac mini with M1 chip or build the pc below:
[PCPartPicker Part List](https://pcpartpicker.com/list/MWLC68)
Type|Item|Price
**CPU** | [AMD Ryzen 5 3600XT 3.8 GHz 6-Core Processor](https://pcpartpicker.com/product/7sFKHx/amd-ryzen-5-3600xt-38-ghz-6-core-processor-100-100000281box) | $233.33 @ Amazon
**Motherboard** | [Asus ROG STRIX B450-F GAMING II ATX AM4 Motherboard](https://pcpartpicker.com/product/xYvqqs/asus-rog-strix-b450-f-gaming-ii-atx-am4-motherboard-rog-strix-b450-f-gaming-ii) | $140.11 @ Amazon
**Memory** | [\*Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory](https://pcpartpicker.com/product/2TFKHx/crucial-ballistix-16-gb-2-x-8-gb-ddr4-3600-memory-bl2k8g36c16u4b) | $74.94 @ Newegg
**Storage** | [Samsung 970 Evo Plus 250 GB M.2-2280 NVME Solid State Drive](https://pcpartpicker.com/product/BDYLrH/samsung-970-evo-plus-250-gb-m2-2280-nvme-solid-state-drive-mz-v7s250bam) | $69.98 @ Amazon
**Storage** | [Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/MwW9TW/western-digital-internal-hard-drive-wd10ezex) | $44.99 @ Adorama
**Case** | [Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case](https://pcpartpicker.com/product/CbqhP6/cooler-master-masterbox-nr600-wo-odd-atx-mid-tower-case-mcb-nr600-kgnn-s00) | $69.98 @ Amazon
**Power Supply** | [Asus ROG Strix 550 W 80+ Gold Certified Fully Modular ATX Power Supply](https://pcpartpicker.com/product/ddJmP6/asus-rog-strix-550-w-80-gold-certified-fully-modular-atx-power-supply-rog-strix-550g) | $123.99 @ Amazon
**Operating System** | [Microsoft Windows 10 Home OEM 64-bit](https://pcpartpicker.com/product/wtgPxr/microsoft-os-kw900140) | $108.78 @ Other World Computing
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$866.10**
 | \*Lowest price parts chosen from parametric criteria |
 | Generated by [PCPartPicker](https://pcpartpicker.com) 2020-11-12 23:51 EST-0500 |
https://linustechtips.com/topic/1268530-please-help-me/
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14206871
Just now, Cubesolveherov2 said:
I edited it now using pcpartpicker can u tell me now
If I get 5600x I think the motherboard might also need to changed so it may exceed the price
tbh if you can get the mac mini for cheaper it may be a better deal but i am quite unfamiliar with their new soc
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14206880
dont get the b450-f, its the same quality as an $80 motherboard masked with nice looks, you will have to buy a new mobo for any cpu upgrades, your also missing a gpu
AMD blackout rig
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14206881
 i am not going to be gaming in 4k or something probably i would  only play Minecraft and GTA for 30min
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14206975
if your going to get b450 get the msi mag tomahawk
AMD blackout rig
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14206982
No you can use use the same B450 board for Ryzen 5000. But, you don't have any kind of GPU you will not have a display output.
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14207237
Country: India
Type|Item|Price
If it is just going to be used for programming and office work you don't need a 3600XT. You can manage with a 3600. What kind of office work exactly are we talking about ? If it is not too intensive then you can just get a Ryzen 3400G and spend more on a high quality keyboard and mouse which you will be using a lot for your work. That APU can handle GTA 5 and Minecraft on normal-high settings.
https://linustechtips.com/topic/1268530-please-help-me/#findComment-14207250
