I have a budget of 1500 Singapore Dollars, which would translate to around 1000$ USD.
I have picked out two laptops which i think are great, but I can't decide on which.
1 ) Asus TUF A15 (S$1507)
Specs : CPU - AMD Ryzen 7 4800H
             GPU - GTX 1660ti
             Ram - 2x8gb 3200ghz
             Storage - 512gb
              Battery - 90wh
2 ) Lenovo Legion 5
             GPU - GTX 1660ti
             Ram - 2x8gb 3200ghz
             Storage - 512gb
             Battery - 60wh
On paper, they look almost similar, but I have a tough time choosing between them as the Asus one has better battery life, and presumably a better upgrade path. BUT the Lenovo one has the better screen, it's the more color accurate option.
Although I will be mostly gaming, I will also be doing some music production.
Thanks in advance!
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
https://linustechtips.com/topic/1268509-help-me-choose/
You really shouldn't get a gaming laptop. Just look at all the threads here of people getting 90, 95, even 100c temps at load, and that's just one of the problems that plague most devices.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206682
Oh okay but well like I said, I will be doing casual gaming of games like Warzone, GTA V etc. so can you recommend me a good model?
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206683
Get a desktop.
SPECS:
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206688
Just now, kelvinhall05 said:
Get a desktop.
Ofcourse I have considered that, infact i had specced out myself a pc, but then I will be moving around quite a bit, so i decided to settle for a laptop.
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206691
SFF desktop then. You are going to have a horrible experience with a gaming laptop.
SPECS:
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206692
aren't small form factors costlier?  Mid tower was what was in my budget back then ( well my dad is buying it for me ) so well we both felt like a laptop is better as we do move around and not be able to carry all the peripherals  ( Monitor, keyboard etc. ) as we are planning to shift countries, so yeah as much as i want a pc, i have to settle on a laptop :(
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206702
I too would highly recommend not getting a gaming laptop, they are heavy, loud and hot. A thin and light and an eGPU could be a good alternative (if you can afford it).
That being said, you asked which of the two options you should get, and so I'll answer that question as well. Personally I'd choose the Lenovo: as a much larger laptop manufacturer they are likely to be better at dealing with any warranty claims I may have. It will also, for that same reason, likely to be easier to get spare parts for the Lenovo in a few years time should you need them. Apparently the cooling system on the Asus is also inferior to that on the Lenovo.
CPU: i7 4790k, RAM: 16GB DDR3, GPU: GTX 1060 6GB
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206705
90 is negligible for a laptop as my Macbook heats up to 95 ish under normal use, so yeah lol, also the lenovo has nice thermals apparently
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206708
Alright thanks a ton man, yeah i too read about better thermals on the Lenovo.
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14206710
             GPU - GTX 1660ti
             Ram - 2x8gb 3200ghz
             Storage - 512gb
              Battery - 90wh
thank you for making me aware of this laptop ill probably run it on the iGPU to save power, the specs are insane for the price IMO though
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14207159
Yeah ik lmao
https://linustechtips.com/topic/1268509-help-me-choose/#findComment-14207241
