Hello, I'm looking for some help with my system, I am afraid that I have done something wrong because I am getting extremely low FPS for my system on Call of Duty: Modern Warfare 2019. My system has an "bronze certified 750W power supply" with an "aorus b550 elite" with a "Ryzen 7 2700x (water cooled, with a single fan radiator)" and a "Nvidia 2080ti founders edition" "duel channel DDR4 2x 8gb Ram". My modern warfare game is on my "Western Digital 4TB black". My temperatures look good with my CPU never exceeding 62 celsius.
My fps on low settings with 90 screen resolution, never exceeds 100 in the warzone map and stays at an average of about 80 and can dip to the low 70 in open fields and more graphically demanding areas of the map. My Nvidia control panel settings are all optimized, and so are my power management setting on my computer. I am debating overclocking all my computer components.
https://linustechtips.com/topic/1268045-low-fps-on-good-system/
turn up your resolution and ingame settings
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1268045-low-fps-on-good-system/#findComment-14202502
Just now, nottylerlt said:
does this help my FPS?
this may help your system be less reliant on your cpu and more on your gpu.
what is your cpu and gpu utilisation percentages?
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1268045-low-fps-on-good-system/#findComment-14202521
3 hours ago, jaslion said:
And what are the fps?
https://linustechtips.com/topic/1268045-low-fps-on-good-system/#findComment-14203051
Whats the gpu and cpu useage (cpu per core). What are the temps for the gpu? What clockspeeds are both cpu and gpu running at during gaming?
https://linustechtips.com/topic/1268045-low-fps-on-good-system/#findComment-14203137
13 hours ago, Rooked said:
PSU is sketchy, change it. It's probably not supplying enough power for your GPU at high load. Get a EVGA Supernova PSU or Corsair PSU. Don't cheap out either! Getting a bad PSU can fry your whole PC and catch on fire.
Just checked my pc again and I made a mistake, I actually have a bronze certified 750W power supply, should I still look into changing it?
https://linustechtips.com/topic/1268045-low-fps-on-good-system/#findComment-14205085
Do you know the model number or brand it is? To be honest I would look for a better PSU like 80+ Gold or 80+ Platinum. That RTX 2080Ti sucks a lot of power. Get a trusted brand though, like Seasonic, Corsair, EVGA. Minimum you would need to get is a 750W PSU and I recommend 800+W PSU.
https://linustechtips.com/topic/1268045-low-fps-on-good-system/#findComment-14206629
