My first pc build so I don’t know much about any of this. I got a 2060 Super founders edition, and I get huge frame drops. My frames in fortnite go from 180 to 17 and fluctuate. It doesn’t matter if I have it capped at 60 or 180, it still drops. Anyone know a possible fix?
https://linustechtips.com/topic/1267697-gpu-help/
Welcome! Please list all the hardware in your build. Do you have the same issue in other games? Latest Nvidia drivers installed (actually, latest driver for everything installed?)?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199680
You might have a dead power supply
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199687
ASRock B450m steel legend motherboard
Ryzen 5 3400G
nvidia GeForce RTX 2060 super founders
corsair CV550 power supply
WD_Black 500 hbu NVMe ssd
2x8 hbu 3200MHz Corsair vengeance pro
yes I have all the latest drivers installed, though I don’t have a windows 10 product key yet. Flight sim and rogue company both have a steady frame rate
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199744
Ryzen 5 3400G
If Fortnite is the only game acting up I'd try re-installing it.
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199748
I had originally installed a gigabyte 1650 ti and it ran consistent frames on fortnite. It wasn’t powerful enough for flight sim, so I sent it back and purchased the 2060 super. The previous card had no frame drops
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199751
Sometimes the GPU drivers can act up when installing a new card. Use DDU to remove all GPU drivers and re-install them and report back.
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199756
My response will probably be tomorrow, thank you for all of the help!
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14199759
Update: I cleaned and reinstalled the drivers, then reinstalled fortnite. The FPS drops are still there...
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14202771
20 hours ago, C Dub Wheat said:
Yes, and completely clueless haha
Do you have anything else running in the background when you play Fortnite?
Downloading anything?
I've had experience with this game being very unstable if I have anything going on in the background.
It could be frame drops, severe lag, momentary freezes etc...
Is it because the game is constantly relaying information to and from the Fortnite servers?
Anyway, try checking you have nothing downloading etc...
I had Steam set up to immediately begin downloading anything that was in my download list as soon as I turned my computer on.
I had to change that.
Check all your stores (Epic, Steam etc...) and make sure they aren't downloading stuff, close anything open in the background, make sure nobody else in your home in online hogging your bandwidth etc...and see if it makes any difference to the stability and consistency of your frame rate.
Not saying it is that, but you didn't mention anything related to it in your OP, and I know from personal experience how much it can interfere with the quality of the experience on Fortnite.
Anyway, hope it is sorted one way or another, mate...good luck.
https://linustechtips.com/topic/1267697-gpu-help/#findComment-14205727
