For the past week, whenever I either restart my computer or boot it up from shut down, the fans are really loud for no reason. My first instinct is that there might be a heavy load on startup but when I check task manager, theres nothing out of the ordinary. The fans do slow down after a couple of minutes but for the first few minutes my laptop gets loud.
My questions are, is this bad and if so, how do I fix it? If there is nothing wrong with the fans ramping up on startup then I won't worry about it but if something is wrong, i want to fix it.
Specs:
Windows 10
HP Envy x360
ryzen 5 4500u
8gb ram
https://linustechtips.com/topic/1267531-loud-fans-on-startup/
Specs:
Windows 10
HP Envy x360
ryzen 5 4500u
8gb ram
Assuming you have no other software trying to control the fans, then ramping of speed is directly tied to the additional load (and therefore heat) generated during startup.
Check for any unnecessary programs that are running during startup ('Startup' tab in Task Manager). Disable any high impact ones you don't use if possible.
If it's been a while since you've cleaned the laptop then I'd do that as well to make sure the cooling system is performing as best as it can.
After doing that, don't worry about it.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1267531-loud-fans-on-startup/#findComment-14198417
