Simple custom loop for a friend
Solved by TheSLSAMG,
I dont think he is gonna break records with his cpu overclock....I ll search for an aio good 240mm .....Also which gtx780ti should he get with the g10 an reference gpu or on like the ghz edition from gigabyte which is overclocked from the to the max
Get an ACX from EVGA. It's a reference design PCB, but a higher clockspeed.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning20
play_circle_filled
Latest From ShortCircuit:
