Hi there
I am currently using a Samsung Q80T TV with the RMCSPT1CP1 remote.
The lower part of the remote has 3 buttons (Netflix and so on). Since I only use one of those buttons I would like to know if you can somehow reprogram those buttons (so that in my case the two buttons that I don't use, get new functions).
Is there any workaround or way to reprogram those?
Thanks in advance
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
https://linustechtips.com/topic/1266704-reprogram-samsung-remote-buttons/
